소개
In this guide you will remove the back cover of the device and locate the two speakers inside. You will then remove the speakers by unsoldering them from motherboard and then replace them.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
필요한 것
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Remove the Speakers
Use the tweezers to remove the speakers from their compartments.
