주요 콘텐츠로 건너뛰기
Supercycle SC1800 Tire Replacement
필요한 것
  1. Supercycle SC1800 Tire Replacement, Tire: 1 단계, 이미지 1개 중 1개
    • Deflate the tire by pressing the valve stem in.
    • If it's difficult to press the stem in with your hands, use a plastic wedge tool.
  2. Supercycle SC1800 Tire Replacement: 2 단계, 이미지 1개 중 1개
    • Once the tire is deflated, press the beading inside until it is removed from the rim.
    • If you need to replace your rim, do it now.
  3. Supercycle SC1800 Tire Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the plastic wedge tool under the beading of the tire, and pull it outwards.
    • The tool is not required, but it makes the job easier.
    • Once the tire is removed from the rim on one side, do the same to other side.
    • Make sure not to puncture the tire tube, as you will need that for the new tire.
  4. Supercycle SC1800 Tire Replacement: 4 단계, 이미지 2개 중 1개 Supercycle SC1800 Tire Replacement: 4 단계, 이미지 2개 중 2개
    • Pull out the tire tube from the tire and transfer it into the new tire.
    • Make sure the valve is facing towards the center as shown in the second picture.
    • If you must replace your tire tube, do it now.
  5. Supercycle SC1800 Tire Replacement: 5 단계, 이미지 1개 중 1개
    • Once the tube is in place, use a little bit of force to get the beading into the rim, making sure the valve goes through the designated hole in the rim.
    • If it starts getting difficult to push the beading with your hands, use the plastic wedge tool to finish.
    • It is important for the valve to correctly line with the valve hole first. Otherwise, you risk damaging the tire tube.
  6. Supercycle SC1800 Tire Replacement: 6 단계, 이미지 1개 중 1개
    • Do the same to both sides of the beading. You will need to use the plastic tool for the other side.
  7. Supercycle SC1800 Tire Replacement: 7 단계, 이미지 1개 중 1개
    • Re-inflate the tire.
    • It may be difficult to re-inflate due to the folds in the deflated tire tube. Be patient!
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Firuz Khandakar
회원 가입일: 09/19/20
219 평판
안내서 1개를 작성함
York University, Team S2-G7, Melo-Thaiss Fall 2020 York University, Team S2-G7, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S2G7
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 21
전체 시간: 1,394
