주요 콘텐츠로 건너뛰기
Supersonic SC-777BT Motherboard Replacement
필요한 것
  1. Supersonic SC-777BT Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Supersonic SC-777BT Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Pry open backing of the tablet using an iFixit opening tool.
  2. Supersonic SC-777BT Motherboard Replacement: 2 단계, 이미지 1/2 Supersonic SC-777BT Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a PH000 screwdriver to unscrew all four motherboard screws.
  3. Supersonic SC-777BT Motherboard Replacement: 3 단계, 이미지 1/3 Supersonic SC-777BT Motherboard Replacement: 3 단계, 이미지 2/3 Supersonic SC-777BT Motherboard Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Unscrew the holder of the camera and gently remove using tweezers.
    • Remove the sensors using tweezers.
  4. Supersonic SC-777BT Motherboard Replacement: 4 단계, 이미지 1/3 Supersonic SC-777BT Motherboard Replacement: 4 단계, 이미지 2/3 Supersonic SC-777BT Motherboard Replacement: 4 단계, 이미지 3/3
    • Detach the battery.
    • Battery is attached with adhesive; no tools needed to remove.
    • Using tweezers, lift and release the ribbon cable that was covered by the battery.
  5. Supersonic SC-777BT Motherboard Replacement: 5 단계, 이미지 1/2 Supersonic SC-777BT Motherboard Replacement: 5 단계, 이미지 2/2
    • Carefully remove the motherboard with your hands.
결론
Maiya Webster
회원 가입일: 09/18/18
364 평판
안내서 2개 작성하였습니다
University of North Texas, Team S4-G4, Raign Fall 2018 University of North Texas, Team S4-G4, Raign Fall 2018 회원
UNT-RAIGN-F18S4G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 8
전체 시간: 300
