주요 콘텐츠로 건너뛰기
Supersonic SC-777BT Touchscreen Sensor Replacement
필요한 것
  1. Supersonic SC-777BT Touchscreen Sensor Replacement, Touchscreen Sensor: 1 단계, 이미지 1/2 Supersonic SC-777BT Touchscreen Sensor Replacement, Touchscreen Sensor: 1 단계, 이미지 2/2
    • Pull the yellow ribbon cable to dislodge the screen from the plastic screen cover.
  2. Supersonic SC-777BT Touchscreen Sensor Replacement: 2 단계, 이미지 1/3 Supersonic SC-777BT Touchscreen Sensor Replacement: 2 단계, 이미지 2/3 Supersonic SC-777BT Touchscreen Sensor Replacement: 2 단계, 이미지 3/3
    • Tear the yellow tape in order to make the front and back covers free to disassemble.
  3. Supersonic SC-777BT Touchscreen Sensor Replacement: 3 단계, 이미지 1/3 Supersonic SC-777BT Touchscreen Sensor Replacement: 3 단계, 이미지 2/3 Supersonic SC-777BT Touchscreen Sensor Replacement: 3 단계, 이미지 3/3
    • Separate the two covers.
    • Put aside the white sheets.
    • Do not put the white sheets on any surface. Only keep them in the covers.
    • Use the tweezers to remove the sting glue and separate the glue from the sensor.
결론
Payton Butler
회원 가입일: 09/18/18
205 평판
안내서 2개 작성하였습니다
University of North Texas, Team S4-G4, Raign Fall 2018 University of North Texas, Team S4-G4, Raign Fall 2018 회원
UNT-RAIGN-F18S4G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 223
