주요 콘텐츠로 건너뛰기
Surface Laptop Studio Battery Replacement
필요한 것
  1. Surface Laptop Studio Battery Replacement, Lower Case: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Battery Replacement: 2 단계, 이미지 1/2 Surface Laptop Studio Battery Replacement: 2 단계, 이미지 2/2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Battery Replacement: 3 단계, 이미지 1/1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Battery Replacement: 4 단계, 이미지 1/1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Battery Replacement: 5 단계, 이미지 1/2 Surface Laptop Studio Battery Replacement: 5 단계, 이미지 2/2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: 6 단계, 이미지 1/2 Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: 6 단계, 이미지 2/2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Battery Replacement, Battery: 7 단계, 이미지 1/2 Surface Laptop Studio Battery Replacement, Battery: 7 단계, 이미지 2/2
    • Pull the pull tabs to release the adhesive securing the battery.
    • Remove the battery.
    • You will need to reattach the new battery with adhesive.
결론
To reassemble your device, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Nate Ball
회원 가입일: 02/14/23
669 평판
안내서 5개 작성하였습니다
댓글 3개
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Omar Abouelseoud - 답글
Are the rubber feet re-attachable to the laptop after repairs?
Any link to buy the battery ?
Alberto Guinea (Shlenderman) - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 70
30일 전: 316
전체 시간: 3,661
