주요 콘텐츠로 건너뛰기
Surface Laptop Studio SSD Replacement
필요한 것
  1. Surface Laptop Studio SSD Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio SSD Replacement: 2 단계, 이미지 2개 중 1개 Surface Laptop Studio SSD Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio SSD Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio SSD Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio SSD Replacement: 5 단계, 이미지 2개 중 1개 Surface Laptop Studio SSD Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: 6 단계, 이미지 2개 중 1개 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: 6 단계, 이미지 2개 중 2개
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio SSD Replacement, SSD: 7 단계, 이미지 1개 중 1개
    • After removing the devices battery, locate the SSD next to the mother board.
  8. Surface Laptop Studio SSD Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the single 3 mm screw that secures the SSD.
  9. Surface Laptop Studio SSD Replacement: 9 단계, 이미지 1개 중 1개
    • Slide the SSD directly out of its socket.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nate Ball
회원 가입일: 02/14/23
741 평판
안내서 5개를 작성함
5가이드 댓글
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - 답글
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - 답글
Can you fit a full sized ssd or only the short ones?
Omega_o7 - 답글
You can fit a full-size (M.2 2280) SSD in the Suface Laptop Studio, but you won't be reusing the metal bracket that is there for the small SDD (2230 size). More info available here: https://dancharblog.wordpress.com/2021/1...
DoktorDread -
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 75
지난 30일: 334
전체 시간: 12,839
