주요 콘텐츠로 건너뛰기
Surface Laptop Studio Surflink Port Replacement
필요한 것
  1. Surface Laptop Studio Surflink Port Replacement, Lower Case: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Surflink Port Replacement: 2 단계, 이미지 1/2 Surface Laptop Studio Surflink Port Replacement: 2 단계, 이미지 2/2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Surflink Port Replacement: 3 단계, 이미지 1/1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Surflink Port Replacement: 4 단계, 이미지 1/1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Surflink Port Replacement: 5 단계, 이미지 1/2 Surface Laptop Studio Surflink Port Replacement: 5 단계, 이미지 2/2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Surflink Port Replacement, Surface Laptop Studio Battery Disconnection: 6 단계, 이미지 1/2 Surface Laptop Studio Surflink Port Replacement, Surface Laptop Studio Battery Disconnection: 6 단계, 이미지 2/2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Surflink Port Replacement, Surflink Port: 7 단계, 이미지 1/3 Surface Laptop Studio Surflink Port Replacement, Surflink Port: 7 단계, 이미지 2/3 Surface Laptop Studio Surflink Port Replacement, Surflink Port: 7 단계, 이미지 3/3
    • Remove the left I/O bracket by unscrewing the the three M1109237 screws with your T3 Torx Screwdriver.
  8. Surface Laptop Studio Surflink Port Replacement: 8 단계, 이미지 1/2 Surface Laptop Studio Surflink Port Replacement: 8 단계, 이미지 2/2
    • Remove the two M1149393 screws that secure the ribbon cable with your T3 Torx screwdriver.
  9. Surface Laptop Studio Surflink Port Replacement: 9 단계, 이미지 1/1
    • Lightly disconnect the flat-top connector by lifting it straight up with an opening tool.
  10. Surface Laptop Studio Surflink Port Replacement: 10 단계, 이미지 1/1
    • Remove the two M1149393 screws that secure the Surflink port with your T3 Torx screwdriver.
  11. Surface Laptop Studio Surflink Port Replacement: 11 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Lift the surflink port out and up with your tweezers.
결론
Nate Ball
회원 가입일: 02/14/23
669 평판
안내서 5개 작성하였습니다
댓글 한 개
Dont even bother reading this unless you already have aquired the surflink port. They are basically impossible to get the parts through ifixit and microsoft. in europe at least.
Robin Trapman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 57
전체 시간: 673
