주요 콘텐츠로 건너뛰기
Surface Studio M.2 SSD Replacement
필요한 것
  1. Surface Studio M.2 SSD Replacement, M.2 SSD: 1 단계, 이미지 3개 중 1개 Surface Studio M.2 SSD Replacement, M.2 SSD: 1 단계, 이미지 3개 중 2개 Surface Studio M.2 SSD Replacement, M.2 SSD: 1 단계, 이미지 3개 중 3개
    • Lay the Surface face down on a padded surface
    • Be careful not to scratch the screen when laying it face down
    • Remove the four rubber feet at each corner concealing the Torx screws
    • Remove the four Torx screws under the rubber feet.
    • Two screws on the upper corners are longer than two screws on the lower corners.
    • Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
  2. Surface Studio M.2 SSD Replacement: 2 단계, 이미지 2개 중 1개 Surface Studio M.2 SSD Replacement: 2 단계, 이미지 2개 중 2개
    • Remove five torx screws holding the two fans to the midframe
    • Remove the two fans
    • The fan connectors are behind the midframe and not yet accessible. Let the fans hang loosely until you can access the connectors.
    • Four large torx screws and four small torx screws hold the midframe to the upper frame.
    • Remove four large torx screws holding the midframe
    • Remove four small torx screws holding the midframe
  3. Surface Studio M.2 SSD Replacement: 3 단계, 이미지 1개 중 1개
    • Slowly remove the midframe
    • Be careful, the speaker on the midframe is still attached to the motherboard
    • Detach the connectors for the two fans and the speaker
  4. Surface Studio M.2 SSD Replacement: 4 단계, 이미지 2개 중 1개 Surface Studio M.2 SSD Replacement: 4 단계, 이미지 2개 중 2개
    • With the midframe removed, the M.2 SSD is now accessible
    • Remove a torx screw holding the M.2 holding the SSD to the motherboard
    • Pull the SSD straight back
    • Do not pull the SSD upward or risk damaging the M.2 socket
    • The M.2 socket is compatible with most SATA III, PCIe ACHI, and PCIe NVMe in the M.2 2280 form factor
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
The Raptor
회원 가입일: 11/27/16
6,276 평판
안내서 6개를 작성함
21가이드 댓글
I know that one of the very first questions would be: Does the M.2 slot supports PCIe NVMe ?
The answer is: Yes it does.
The Raptor - 답글
But it does not mean that you can get the drive to run in NVMe model.
There does not appear to be a setting to enable NVMe model for the drive.
John -
Does it support bootable NVMe?
Mark Smith - 답글
@msmith4099 @theofficemaven
Sure. When installing Windows, choose to install Windows to "Drive 1" instead of "Drive 0"
The Raptor -
Is there any raid options that need to be configured?
Mark Smith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 30
지난 30일: 135
전체 시간: 13,237
