이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전 으로 전환하십시오.
Does your surfboard have a broken or loose fin? This guide will help you replace your surfboard fin to get you back on the water in no time!
With your new or repaired fin, insert the back in first so that you feel the inlet on the fin clip into the little rod in the slit.
Once you feel the back secure, bring the front of the fin down into the slit.
Place the screw back into the hole and begin turning clockwise using the key.
Continue turning until the screw is tight and won't turn any more.
Once the screw stops turning, do not continue to tighten or you may damage the screw or fin.
Make sure the screw can no longer be seen.
Wiggle your fin gently to test for looseness, and you have successfully replaced your surfboard fin.
해당 안내서 넣기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
단일 단계
전체 안내서
소형 - 600px
중형 - 800px
대형 - 1200px
미리보기
