주요 콘텐츠로 건너뛰기
Surfboard Futures Fin Replacement
필요한 것
  1. Surfboard Futures Fin Replacement, Futures Fin: 1 단계, 이미지 3개 중 1개 Surfboard Futures Fin Replacement, Futures Fin: 1 단계, 이미지 3개 중 2개 Surfboard Futures Fin Replacement, Futures Fin: 1 단계, 이미지 3개 중 3개
    • Lay your surfboard down on a flat, durable surface long enough to support the length of your board.
  2. Surfboard Futures Fin Replacement: 2 단계, 이미지 3개 중 1개 Surfboard Futures Fin Replacement: 2 단계, 이미지 3개 중 2개 Surfboard Futures Fin Replacement: 2 단계, 이미지 3개 중 3개
    • Make sure the small screw hole in front of the fin is free of debris and sand.
    • Insert the key into the hole and begin turning counter-clockwise to loosen the screw inside.
  3. Surfboard Futures Fin Replacement: 3 단계, 이미지 2개 중 1개 Surfboard Futures Fin Replacement: 3 단계, 이미지 2개 중 2개
    • Continue turning counter-clockwise until the screw is free.
  4. Surfboard Futures Fin Replacement: 4 단계, 이미지 3개 중 1개 Surfboard Futures Fin Replacement: 4 단계, 이미지 3개 중 2개 Surfboard Futures Fin Replacement: 4 단계, 이미지 3개 중 3개
    • Firmly grasp the fin with one hand and place your other hand on the surfboard for stabilization.
    • Simultaneously lift the fin while tilting it backwards to remove the fin.
  5. Surfboard Futures Fin Replacement: 5 단계, 이미지 2개 중 1개 Surfboard Futures Fin Replacement: 5 단계, 이미지 2개 중 2개
    • Notice the circular inlet on the rear bottom side of the fin. This inlet of the fin fits snuggly into the little rod located in the back of the fin slit on the board, much like a puzzle.
  6. Surfboard Futures Fin Replacement: 6 단계, 이미지 3개 중 1개 Surfboard Futures Fin Replacement: 6 단계, 이미지 3개 중 2개 Surfboard Futures Fin Replacement: 6 단계, 이미지 3개 중 3개
    • With your new or repaired fin, insert the back in first so that you feel the inlet on the fin clip into the little rod in the slit.
    • Once you feel the back secure, bring the front of the fin down into the slit.
  7. Surfboard Futures Fin Replacement: 7 단계, 이미지 3개 중 1개 Surfboard Futures Fin Replacement: 7 단계, 이미지 3개 중 2개 Surfboard Futures Fin Replacement: 7 단계, 이미지 3개 중 3개
    • Place the screw back into the hole and begin turning clockwise using the key.
    • Continue turning until the screw is tight and won't turn any more.
    • Once the screw stops turning, do not continue to tighten or you may damage the screw or fin.
  8. Surfboard Futures Fin Replacement: 8 단계, 이미지 1개 중 1개
    • Make sure the screw can no longer be seen.
    • Wiggle your fin gently to test for looseness, and you have successfully replaced your surfboard fin.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hudson Albert
회원 가입일: 09/29/15
165 평판
안내서 1개를 작성함
Cal Poly, Team 10-3, Green Fall 2015 Cal Poly, Team 10-3, Green Fall 2015 회원
CPSU-GREEN-F15S10G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 18
전체 시간: 4,670
