주요 콘텐츠로 건너뛰기
Stapler Spring Replacement
필요한 것
  1. Stapler Spring Replacement, Spring: 1 단계, 이미지 2개 중 1개 Stapler Spring Replacement, Spring: 1 단계, 이미지 2개 중 2개
    • Open the stapler by gripping the handle to access the spring.
  2. Stapler Spring Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Pry open the hook found on the pusher using the tweezers.
    • Hold the handle firmly to prevent the stapler from snapping back.
  3. Stapler Spring Replacement: 3 단계, 이미지 1개 중 1개
    • Unhook the end of the spring from the pusher.
    • Pinch the spring firmly between your fingers to keep it from snapping back.
  4. Stapler Spring Replacement: 4 단계, 이미지 2개 중 1개 Stapler Spring Replacement: 4 단계, 이미지 2개 중 2개
    • Unhook the other end of the spring from the inside of the handle.
    • The spring should be unthreaded from the holes on the handle's metal part.
  5. Stapler Spring Replacement: 5 단계, 이미지 2개 중 1개 Stapler Spring Replacement: 5 단계, 이미지 2개 중 2개
    • Press down on the metal part inside the handle with your thumbs until it will not go down anymore.
  6. Stapler Spring Replacement: 6 단계, 이미지 2개 중 1개 Stapler Spring Replacement: 6 단계, 이미지 2개 중 2개
    • Push the hammer, the rectangular piece, up and away from the metal part.
  7. Stapler Spring Replacement: 7 단계, 이미지 1개 중 1개
    • Release the metal part inside the handle so it comes away from the hammer.
    • Keep hold of the metal part to keep it from snapping closed.
  8. Stapler Spring Replacement: 8 단계, 이미지 1개 중 1개
    • Hook one end of the new spring onto the pusher's hook.
  9. Stapler Spring Replacement: 9 단계, 이미지 1개 중 1개
    • Clamp the pusher's hook closed using your thumb.
  10. Stapler Spring Replacement: 10 단계, 이미지 1개 중 1개
    • Thread the other end of the new spring through the top rectangular hole toward the back.
  11. Stapler Spring Replacement: 11 단계, 이미지 1개 중 1개
    • Thread the new spring through the bottom hole, bringing the end of spring toward you.
    • The spring should create a loop when done threading.
  12. Stapler Spring Replacement: 12 단계, 이미지 2개 중 1개 Stapler Spring Replacement: 12 단계, 이미지 2개 중 2개
    • Hook the new spring to the hook on the inside of the handle's metal part.
  13. Stapler Spring Replacement: 13 단계, 이미지 2개 중 1개 Stapler Spring Replacement: 13 단계, 이미지 2개 중 2개
    • Press the metal part down with your thumbs until it aligns with the hammer's hole.
  14. Stapler Spring Replacement: 14 단계, 이미지 2개 중 1개 Stapler Spring Replacement: 14 단계, 이미지 2개 중 2개
    • Reattach the hammer back onto the metal part.
  15. Stapler Spring Replacement: 15 단계, 이미지 2개 중 1개 Stapler Spring Replacement: 15 단계, 이미지 2개 중 2개
    • Close the handle until it clicks back into place.
    • Be careful not to staple your fingers when closing the stapler.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lauren McCabe
회원 가입일: 01/16/20
349 평판
안내서 1개를 작성함
댓글 13개
Just what I needed. Thank you! Super clear
Daniela Labra - 답글
Can I replace the black rubber piece that goes on my swingling desk top stapler 70 sheet it came off and my dog chewed it up.
Edith Corkell - 답글
fron this sale ski o donde venden los repuestos de esta engrapadora en Venezuela gran caracas
Romulo -
Ihr Artikel war sehr leicht zu verstehen und ich habe es geschafft, vielen Dank gacha life!
Lily Collins - 답글
댓글 쓰기
조회 통계:
지난 24시간: 219
지난 7일: 1,330
지난 30일: 5,341
전체 시간: 214,672
