소개
At Unterdruckbenzinhähne it can always lead to problems with the gasoline supply and leaks. That's why it should be checked and cleaned again and again. Here's a guide to the complete seal replacement on a Suzuki DR650SE SP46B. Please use original parts. (Already had problems with accessories)
필요한 것
The two screws, here quite funny with a large Phillips, or a 10-fork or ring spanner, unscrew.
Very important: The tank should be at most 1/4 full so that it does not leak. Then you can put it upright.
Re-screw the 5 Phillips screws with a suitable Phillips screwdriver (PH2).
gasoline connection
Vacuum port
For functional testing, you must now apply a slight vacuum to the vacuum connection, which causes the cap to open. This can then be tested by blowing at the gasoline connection. When the vacuum drops, the shutter must close immediately.
Now install the foot gasket.
다음 번역가들에게 특별히 감사 드립니다:
100%
irlanda님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
