주요 콘텐츠로 건너뛰기
Suzuki FA50 Moped Exhaust Pipe Replacement
필요한 것
  1. Suzuki FA50 Moped Exhaust Pipe Replacement, Exhaust Pipe: 1 단계, 이미지 1/1
    • Use a #2 Phillips screwdriver to remove the heat shield from the muffler.
  2. Suzuki FA50 Moped Exhaust Pipe Replacement: 2 단계, 이미지 1/1
    • There are two 10 mm hex nuts attaching the muffler to the engine. Make sure you remove both of them before proceeding to the next step.
    • Use a 10 mm socket wrench to unscrew the two hex nuts.
  3. Suzuki FA50 Moped Exhaust Pipe Replacement: 3 단계, 이미지 1/1
    • Use a 12 mm socket wrench to unscrew the third and final hex nut that holds the muffler in place.
    • Make sure to support the muffler with your hand while removing this nut, otherwise it may just fall to the floor.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Miroslav Djuric
158,300 평판
안내서 144개 작성하였습니다
댓글 한 개
Thanks you very much! Happy Fourth of July.
D4Tay - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 6,780
