주요 콘텐츠로 건너뛰기
SwagTron T1 Gyroscope Replacement
필요한 것
  1. SwagTron T1 Gyroscope Replacement, Back Panels: 1 단계, 이미지 1개 중 1개
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Gyroscope Replacement: 2 단계, 이미지 3개 중 1개 SwagTron T1 Gyroscope Replacement: 2 단계, 이미지 3개 중 2개 SwagTron T1 Gyroscope Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Gyroscope Replacement: 3 단계, 이미지 3개 중 1개 SwagTron T1 Gyroscope Replacement: 3 단계, 이미지 3개 중 2개 SwagTron T1 Gyroscope Replacement: 3 단계, 이미지 3개 중 3개
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Gyroscope Replacement, Gyroscope: 4 단계, 이미지 2개 중 1개 SwagTron T1 Gyroscope Replacement, Gyroscope: 4 단계, 이미지 2개 중 2개
    • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
  5. SwagTron T1 Gyroscope Replacement: 5 단계, 이미지 1개 중 1개
    • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
  6. SwagTron T1 Gyroscope Replacement: 6 단계, 이미지 3개 중 1개 SwagTron T1 Gyroscope Replacement: 6 단계, 이미지 3개 중 2개 SwagTron T1 Gyroscope Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully remove the gyroscope component from the SwagTron.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Teagan Allen
회원 가입일: 04/18/17
432 평판
안내서 2개를 작성함
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G5
4 회원들
안내서 5개를 작성함
5가이드 댓글
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - 답글
Amazon.com Keyword: CertiCable
Jesse Griffis -
Where do you get the replacement?
Brittany Conner - 답글
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - 답글
I just got mine today and after the first hour I ran into a shoe and then I tried recalibrating it but it was no use. If someone knows what’s going on please tell me! Thank you :)
Elia Leon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 27
전체 시간: 7,851
