주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SwagTron T1 Outer Shell Replacement
필요한 것
  1. SwagTron T1 Outer Shell Replacement, Back Panels: 1 단계, 이미지 1개 중 1개
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Outer Shell Replacement: 2 단계, 이미지 3개 중 1개 SwagTron T1 Outer Shell Replacement: 2 단계, 이미지 3개 중 2개 SwagTron T1 Outer Shell Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Outer Shell Replacement: 3 단계, 이미지 3개 중 1개 SwagTron T1 Outer Shell Replacement: 3 단계, 이미지 3개 중 2개 SwagTron T1 Outer Shell Replacement: 3 단계, 이미지 3개 중 3개
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Outer Shell Replacement, Outer Shell: 4 단계, 이미지 2개 중 1개 SwagTron T1 Outer Shell Replacement, Outer Shell: 4 단계, 이미지 2개 중 2개
    • Unscrew the twelve 10mm screws that connect the metal chassis to the top plastic panel.
    • These screws will be low into the SwagTron.
  5. SwagTron T1 Outer Shell Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the SwagTron right side up and slightly lift up the panel.
    • Be careful to not pull too hard because the panel is still attached to the SwagTron by wires.
  6. SwagTron T1 Outer Shell Replacement: 6 단계, 이미지 3개 중 1개 SwagTron T1 Outer Shell Replacement: 6 단계, 이미지 3개 중 2개 SwagTron T1 Outer Shell Replacement: 6 단계, 이미지 3개 중 3개
    • Turn the SwagTron over and disconnect the wires from the motherboard.
    • Follow the wires to the underside of the SwagTron.
    • Carefully remove the cord and the panel together.
    • All the panels are now free from the SwagTron.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Gloria Whang
회원 가입일: 04/13/17
185 평판
안내서 1개를 작성함
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G5
4 회원들
안내서 5개를 작성함
4가이드 댓글
Where did you ind a replacement shell for the Swagtron T1? I need to buy a new one, but can’t seem to find a place to buy it online.
Syd Jensen - 답글 공유
Where can I buy a Swagtron T1 replacement shell?
Syd Jensen - 답글 공유
Syd any luck finding a replacement shell?  I need to order the same kind and cannot find it online.
Craig - 답글 공유
Amazon.com Keyword: CertiCable
Jesse Griffis - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 52
전체 시간: 2,364
