주요 콘텐츠로 건너뛰기
Swann Doorphone Video Intercom Microphone Replacement
필요한 것
  1. Swann Doorphone Video Intercom Microphone Replacement, Microphone: 1 단계, 이미지 1/3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: 1 단계, 이미지 2/3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: 1 단계, 이미지 3/3
    • Flip the monitor of the Swann Doorphone Video Intercom over so that the underside is facing up.
    • Remove the six 2 mm corner screws from the back plate of the monitor using the JIS #0 screwdriver.
  2. Swann Doorphone Video Intercom Microphone Replacement: 2 단계, 이미지 1/2 Swann Doorphone Video Intercom Microphone Replacement: 2 단계, 이미지 2/2
    • Once the screws are removed, grip the black back plate of the monitor and remove from the monitor.
    • The back plate will still be connected to the monitor with a cord of wires that should not be removed.
  3. Swann Doorphone Video Intercom Microphone Replacement: 3 단계, 이미지 1/3 Swann Doorphone Video Intercom Microphone Replacement: 3 단계, 이미지 2/3 Swann Doorphone Video Intercom Microphone Replacement: 3 단계, 이미지 3/3
    • Using the precision tweezers, grab the sides of the white connector at the bottom of the green board.
    • Pull the white connector towards you to disconnect the board.
  4. Swann Doorphone Video Intercom Microphone Replacement: 4 단계, 이미지 1/3 Swann Doorphone Video Intercom Microphone Replacement: 4 단계, 이미지 2/3 Swann Doorphone Video Intercom Microphone Replacement: 4 단계, 이미지 3/3
    • Grip the other end of the white connector cable towards the base of the black microphone.
    • Pull gently towards your body to remove the microphone.
결론
Emily Stenke
회원 가입일: 02/14/18
555 평판
안내서 4개 작성하였습니다
USF Tampa, Team S2-G4, Eyestone Spring 2018 USF Tampa, Team S2-G4, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S2G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 342
