주요 콘텐츠로 건너뛰기
Swiffer SweeperVac Battery Replacement (PG3000)
필요한 것
  1. Swiffer SweeperVac Battery Replacement (PG3000), Battery: 1 단계, 이미지 1/2 Swiffer SweeperVac Battery Replacement (PG3000), Battery: 1 단계, 이미지 2/2
    • Unscrew seven 17.95 mm screws on the side of the device.
    • Unscrew the 13.87 mm screw.
  2. Swiffer SweeperVac Battery Replacement (PG3000): 2 단계, 이미지 1/1
    • Find the sticker on the back of the device. It may have already been removed.
    • If there is a sticker, peel it back from either half of the device.
  3. Swiffer SweeperVac Battery Replacement (PG3000): 3 단계, 이미지 1/2 Swiffer SweeperVac Battery Replacement (PG3000): 3 단계, 이미지 2/2
    • Firmly, but carefully grip each half of the case and split it open.
  4. Swiffer SweeperVac Battery Replacement (PG3000): 4 단계, 이미지 1/1
    • Remove the silver-colored battery cap from the top of the battery.
  5. Swiffer SweeperVac Battery Replacement (PG3000): 5 단계, 이미지 1/1
    • Lift the attached battery from the device and place it on the surface.
    • Remove the second silver-colored battery cap from the bottom of the interior of the device.
  6. Swiffer SweeperVac Battery Replacement (PG3000): 6 단계, 이미지 1/1
    • Using the spudger, apply pressure to the lock on the black wire attachment.
    • While pressure is being applied to the lock, pull the black wire away from the battery.
  7. Swiffer SweeperVac Battery Replacement (PG3000): 7 단계, 이미지 1/2 Swiffer SweeperVac Battery Replacement (PG3000): 7 단계, 이미지 2/2
    • Using the spudger, apply pressure to the lock on the red wire attachment.
    • While pressure is being applied to the lock, pull the red wire away from the battery.
    • When installing the new battery, you do not need to press down on the locks. Simply plug the wires into the appropriate sockets on the new battery.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Alexander Boesenberg
회원 가입일: 09/22/14
808 평판
안내서 3개 작성하였습니다
USF Tampa, Team 10-3, Brown Fall 2014 USF Tampa, Team 10-3, Brown Fall 2014 회원
USFT-BROWN-F14S10G3
3 회원들
안내서 9개 작성하였습니다
댓글 10개
This seems very easy. Will try amd make an update
eli3danimator - 답글
This was helpful but my swiffer vacuum had a plastic chassis for the battery and I had to remove the circuit board as well to route the wires on my replacement battery as they were not is the same places as the factory battery.
lillysilbert - 답글
Where do you purchase the batteries
deniseward640 - 답글
Where do you purchase the batteries?
deniseward640 - 답글
One place you can get the battery pack as shown is here; https://sweeperbattery.com/. The latest model (easier to install) battery in a case (6 cell - 7.2 volt) is also available from amazon.
Dwight Cooper - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 83
30일 전: 294
전체 시간: 62,669
