주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Swimming Pool Diving Board Replacement
필요한 것
  1. Swimming Pool Diving Board Replacement, Diving Board: 1 단계, 이미지 3개 중 1개 Swimming Pool Diving Board Replacement, Diving Board: 1 단계, 이미지 3개 중 2개 Swimming Pool Diving Board Replacement, Diving Board: 1 단계, 이미지 3개 중 3개
    • Using a ratchet, 5/16" Allen hex socket, and 3/4" box wrench, unscrew the fastener where the diving board meets the top of the spring.
  2. Swimming Pool Diving Board Replacement: 2 단계, 이미지 3개 중 1개 Swimming Pool Diving Board Replacement: 2 단계, 이미지 3개 중 2개 Swimming Pool Diving Board Replacement: 2 단계, 이미지 3개 중 3개
    • Use a ratchet and 15/16" short socket to unthread the 4 hex head fasteners from the fiber glass base.
  3. Swimming Pool Diving Board Replacement: 3 단계, 이미지 3개 중 1개 Swimming Pool Diving Board Replacement: 3 단계, 이미지 3개 중 2개 Swimming Pool Diving Board Replacement: 3 단계, 이미지 3개 중 3개
    • After 4 nylock hex head fasteners have been removed, lift the fiber glass base from the 4 threaded studs that are protruding from the concrete.
  4. Swimming Pool Diving Board Replacement: 4 단계, 이미지 3개 중 1개 Swimming Pool Diving Board Replacement: 4 단계, 이미지 3개 중 2개 Swimming Pool Diving Board Replacement: 4 단계, 이미지 3개 중 3개
    • Remove 2 fasteners where the diving board meets the fiber glass base using the 5/16" Allen hex socket and the 3/4" hex nylock nut.
    • Set the base and board on a stable elevated surface like a table to make it easy to access the parts under the base.
  5. Swimming Pool Diving Board Replacement: 5 단계, 이미지 3개 중 1개 Swimming Pool Diving Board Replacement: 5 단계, 이미지 3개 중 2개 Swimming Pool Diving Board Replacement: 5 단계, 이미지 3개 중 3개
    • To attach the new diving board, fasten the fiber glass base to the diving board using button head bolts, washers, gaskets, and nylock nuts.
    • Do not fasten the board to the fiber glass base too tightly as jumping on it while it is too tight can overload the diving board.
  6. Swimming Pool Diving Board Replacement: 6 단계, 이미지 2개 중 1개 Swimming Pool Diving Board Replacement: 6 단계, 이미지 2개 중 2개
    • Mount the base with the new diving board back onto the 4 threaded studs protruding from the ground.
  7. Swimming Pool Diving Board Replacement: 7 단계, 이미지 3개 중 1개 Swimming Pool Diving Board Replacement: 7 단계, 이미지 3개 중 2개 Swimming Pool Diving Board Replacement: 7 단계, 이미지 3개 중 3개
    • Thread the 15/16" nylock nuts and washers onto stud anchors.
  8. Swimming Pool Diving Board Replacement: 8 단계, 이미지 3개 중 1개 Swimming Pool Diving Board Replacement: 8 단계, 이미지 3개 중 2개 Swimming Pool Diving Board Replacement: 8 단계, 이미지 3개 중 3개
    • Using a ratchet, 5/16" Allen hex socket, and 3/4" box wrench, screw on the fastener where the diving board meets the top of the spring.
결론
Now that you have replaced your diving board, make sure to test it out! That spring will give you a greater bounce than a traditional diving board!
작성자
1다른 기여자 명과 함께
Michael Rodriguez
회원 가입일: 10/25/23
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 104
전체 시간: 941
