이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will pictorially show you how to detect an age failed pump strainer cover o-ring. Replacing actual o-ring is very trivial so that won't be shown.
Bubbles visible in strainer chamber (or at outlet jets)? Bend oring at extreme angle as shown. If tiny fissures are apparent as in photo a new o-ring will solve the issue.
다른 한 분이 해당 안내서를 완성하였습니다.
