주요 콘텐츠로 건너뛰기
Sylvania SDVD9004 Motherboard Replacement
필요한 것
  1. Sylvania SDVD9004 Motherboard Replacement, Back cover: 1 단계, 이미지 1/1
    • Remove ten 7mm Phillips #0 screws.
    • Remove four 5mm Phillips #0 screws.
  2. Sylvania SDVD9004 Motherboard Replacement: 2 단계, 이미지 1/2 Sylvania SDVD9004 Motherboard Replacement: 2 단계, 이미지 2/2
    • Flip the device over.
    • Lift the top.
  3. Sylvania SDVD9004 Motherboard Replacement: 3 단계, 이미지 1/1
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
  4. Sylvania SDVD9004 Motherboard Replacement, CD Drive: 4 단계, 이미지 1/3 Sylvania SDVD9004 Motherboard Replacement, CD Drive: 4 단계, 이미지 2/3 Sylvania SDVD9004 Motherboard Replacement, CD Drive: 4 단계, 이미지 3/3
    • Wedge head lightly between drive and bottom of tab.
    • Repeat on both sides.
    • Gently pull out ribbon
  5. Sylvania SDVD9004 Motherboard Replacement: 5 단계, 이미지 1/1
    • Drive Removal
    • Use Philip's screw driver to remove three 7 mm screws.
    • Rotate counter clockwise to loosen screws.
  6. Sylvania SDVD9004 Motherboard Replacement: 6 단계, 이미지 1/1
    • Follow the red and black cables to the motherboard point of attachment.
    • Use a Flat head screwdriver.
    • Place head of driver into the grove of plug and port.
    • Wedge on all sides evenly to work out plug slowly.
    • Remove small and large plugs.
  7. Sylvania SDVD9004 Motherboard Replacement, Motherboard: 7 단계, 이미지 1/3 Sylvania SDVD9004 Motherboard Replacement, Motherboard: 7 단계, 이미지 2/3 Sylvania SDVD9004 Motherboard Replacement, Motherboard: 7 단계, 이미지 3/3
    • Remove Ribbon from Rear Panel
  8. Sylvania SDVD9004 Motherboard Replacement: 8 단계, 이미지 1/1
    • Anchor screw removal
    • Use Philip's head screwdriver
    • Place head of driver into screw on mother board.
    • Remove all four screws
  9. Sylvania SDVD9004 Motherboard Replacement: 9 단계, 이미지 1/1
    • Lift motherboard to expose battery
결론
Sarah Henry
회원 가입일: 10/31/16
417 평판
안내서 4개 작성하였습니다
Baylor, Team 5-10, Williams Fall 2016 Baylor, Team 5-10, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G10
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 384
