주요 콘텐츠로 건너뛰기
Synology DiskStation DS412+ RAM Replacement
필요한 것
  1. Synology DiskStation DS412+ RAM Replacement, DS412+: 1 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement, DS412+: 1 단계, 이미지 2/2
    • DS412+
    • Remove the front panel
  2. Synology DiskStation DS412+ RAM Replacement: 2 단계, 이미지 1/1
    • Remove the hard disks
  3. Synology DiskStation DS412+ RAM Replacement: 3 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 3 단계, 이미지 2/2
    • Remove the two screws in the back of the NAS, on the top and bottom.
  4. Synology DiskStation DS412+ RAM Replacement: 4 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 4 단계, 이미지 2/2
    • Locate those 2 tabs on the left side inside the device.
    • Lift them up off the metal brace
    • You may have to bend the metal support bar to remove the case. Bend it back if you do.
  5. Synology DiskStation DS412+ RAM Replacement: 5 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 5 단계, 이미지 2/2
    • Push the case away towards the back about 1 cm
  6. Synology DiskStation DS412+ RAM Replacement: 6 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 6 단계, 이미지 2/2
    • With the NAS on its right side, lift up the enclosure, mind the tabs on the top of the case.
  7. Synology DiskStation DS412+ RAM Replacement: 7 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 7 단계, 이미지 2/2
    • Remove the screw securing the HDD bays enclosure.
  8. Synology DiskStation DS412+ RAM Replacement: 8 단계, 이미지 1/1
    • Remove the screw securing the I/O board.
  9. Synology DiskStation DS412+ RAM Replacement: 9 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 9 단계, 이미지 2/2
    • Remove the four screws securing the HDD bays
  10. Synology DiskStation DS412+ RAM Replacement: 10 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 10 단계, 이미지 2/2
    • Pull the fan a little bit away
  11. Synology DiskStation DS412+ RAM Replacement: 11 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 11 단계, 이미지 2/2
    • Watch out for this plug
    • Lift the metal bracket out
  12. Synology DiskStation DS412+ RAM Replacement: 12 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 12 단계, 이미지 2/2
    • Remove the fan power headers
  13. Synology DiskStation DS412+ RAM Replacement: 13 단계, 이미지 1/1
    • Remove the I/O board by lifting it up
  14. Synology DiskStation DS412+ RAM Replacement: 14 단계, 이미지 1/2 Synology DiskStation DS412+ RAM Replacement: 14 단계, 이미지 2/2
    • Remove those 4 screws
  15. Synology DiskStation DS412+ RAM Replacement: 15 단계, 이미지 1/1
    • Starting from the front of the unit, remove the motherboard from the unit.
  16. Synology DiskStation DS412+ RAM Replacement: 16 단계, 이미지 1/3 Synology DiskStation DS412+ RAM Replacement: 16 단계, 이미지 2/3 Synology DiskStation DS412+ RAM Replacement: 16 단계, 이미지 3/3
    • Pull these tabs and remove the ram
    • Old and new Ram
    • The old RAM's part number is: M3SN-1GSFCCM7-GA14
    • To reassemble your device, follow these instructions in reverse order.
결론
다른 35명이 해당 안내서를 완성하였습니다.
gieljnssns
회원 가입일: 06/26/11
981 평판
안내서 1개 작성함
댓글 18개
Hi is it also possible with a Synology ds216play? Or is the RAM not modular in this Drives?
markusguenther30684 - 답글
Very nice guide. Thank you!
mbs - 답글
Thank you for the guide, just to ease it up a bit for everybody following, the best way to pull the two tabs from step 4 was to use small spoon (or anything metal) and use it as a crowbar from the inside (do not try to put force from the outer rim, but really from inside of the Synology itself (against the metal beam the tabs are holding to).
Ondrej Palat - 답글
Thank you very much.
Olivier Claude - 답글
did these steps and now my DS412+ won't boot anymore. just the blue power light for a few seconds, no hard drive or fan will turn on.
after putting the old RAM in the slot nothing changed. cannot find any error, how do I find out what's wrong here???
Andreas Hanny - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 34
30일 전: 176
전체 시간: 24,497
