주요 콘텐츠로 건너뛰기
Syntus ST150 Ultrasonic Plate Replacement
필요한 것
  1. Syntus ST150 Ultrasonic Plate Replacement, Ultrasonic Plate: 1 단계, 이미지 1/1
    • First, make sure the water tank inside the diffuser is completely dry to avoid any water from contacting the internal components.
    • Make sure the diffuser is disconnected from the power source to avoid electrical hazards.
  2. Syntus ST150 Ultrasonic Plate Replacement: 2 단계, 이미지 1/2 Syntus ST150 Ultrasonic Plate Replacement: 2 단계, 이미지 2/2
    • With a Phillips #1 screwdriver, remove the three 10 mm screws on the bottom of the diffuser.
  3. Syntus ST150 Ultrasonic Plate Replacement: 3 단계, 이미지 1/3 Syntus ST150 Ultrasonic Plate Replacement: 3 단계, 이미지 2/3 Syntus ST150 Ultrasonic Plate Replacement: 3 단계, 이미지 3/3
    • Lift the water tank while holding the base of the diffuser.
    • Disconnect the three cables form the board.
    • Make sure when reassembling the diffuser to plug in each cable to its assigned port.
  4. Syntus ST150 Ultrasonic Plate Replacement: 4 단계, 이미지 1/3 Syntus ST150 Ultrasonic Plate Replacement: 4 단계, 이미지 2/3 Syntus ST150 Ultrasonic Plate Replacement: 4 단계, 이미지 3/3
    • To separate the board from the water tank, unscrew the three Phillips #1 10 mm screws securing the board.
  5. Syntus ST150 Ultrasonic Plate Replacement: 5 단계, 이미지 1/3 Syntus ST150 Ultrasonic Plate Replacement: 5 단계, 이미지 2/3 Syntus ST150 Ultrasonic Plate Replacement: 5 단계, 이미지 3/3
    • With a Phillips #0 screwdriver, remove the three 7 mm screws from the ultrasonic sensor cover.
    • Remove the cover to expose the ultrasonic sensor.
  6. Syntus ST150 Ultrasonic Plate Replacement: 6 단계, 이미지 1/3 Syntus ST150 Ultrasonic Plate Replacement: 6 단계, 이미지 2/3 Syntus ST150 Ultrasonic Plate Replacement: 6 단계, 이미지 3/3
    • Detach the ultrasonic sensor from the water tank.
    • Detach the ultrasonic sensor connector from the board.
  7. Syntus ST150 Ultrasonic Plate Replacement: 7 단계, 이미지 1/1
    • Remove the rubber cover from the ultrasonic plate.
  8. Syntus ST150 Ultrasonic Plate Replacement: 8 단계, 이미지 1/1
    • Now you can replace the ultrasonic plate of your diffuser.
결론
Alejandro R. Calderin Anzueta
회원 가입일: 03/23/22
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 26
전체 시간: 563
