주요 콘텐츠로 건너뛰기
T-Mobile Huawei Prism U8651T Battery Replacement
필요한 것
  1. T-Mobile Huawei Prism U8651T Battery Replacement, Remove Back Cover Panel: 1 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Battery Replacement, Remove Back Cover Panel: 1 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Battery Replacement, Remove Back Cover Panel: 1 단계, 이미지 3/3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T Battery Replacement, Remove Battery: 2 단계, 이미지 1/3 T-Mobile Huawei Prism U8651T Battery Replacement, Remove Battery: 2 단계, 이미지 2/3 T-Mobile Huawei Prism U8651T Battery Replacement, Remove Battery: 2 단계, 이미지 3/3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
    • Be sure to use the new battery during reassembly.
결론
Dillon
회원 가입일: 10/23/14
578 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-7, Lauer Fall 2014 Michigan Tech, Team 1-7, Lauer Fall 2014 회원
MTU-LAUER-F14S1G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 627
