주요 콘텐츠로 건너뛰기
T-Mobile Huawei Prism U8651T LCD Replacement
필요한 것
  1. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: 1 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: 1 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Back Cover Panel: 1 단계, 이미지 3개 중 3개
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: 2 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: 2 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Battery: 2 단계, 이미지 3개 중 3개
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: 3 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: 3 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Torx Screws: 3 단계, 이미지 3개 중 3개
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: 4 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: 4 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Plastic Mid Frame: 4 단계, 이미지 3개 중 3개
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: 5 단계, 이미지 2개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power and Volume Buttons: 5 단계, 이미지 2개 중 2개
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: 6 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: 6 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Power Button Sensor Strip: 6 단계, 이미지 3개 중 3개
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: 7 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: 7 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Volume Button Sensor Strip: 7 단계, 이미지 3개 중 3개
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: 8 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: 8 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Outer Screen Connector: 8 단계, 이미지 3개 중 3개
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: 9 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: 9 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Inner Screen Connector: 9 단계, 이미지 3개 중 3개
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: 10 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: 10 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Motherboard: 10 단계, 이미지 3개 중 3개
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: 11 단계, 이미지 3개 중 1개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: 11 단계, 이미지 3개 중 2개 T-Mobile Huawei Prism U8651T LCD Replacement, Remove Screen: 11 단계, 이미지 3개 중 3개
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dillon
회원 가입일: 10/23/14
578 평판
안내서 5개를 작성함
Michigan Tech, Team 1-7, Lauer Fall 2014 Michigan Tech, Team 1-7, Lauer Fall 2014 회원
MTU-LAUER-F14S1G7
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 998
