주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If you are running into issues with the LCD not working properly on your T-Mobile Huawei Prism U8651T LCD, this guide will show you how to replace it.
부품
지정된 부품이 없습니다.
  1. Place the phone face down. Slide the back cover panel away from you, until you hear a click. Lift the back cover panel off.
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. Place the plastic opening tool in the gap between the camera and battery. Pry the battery up. Remove the battery.
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. Locate the six  3mm torx screws holding the plastic mid frame in place. Remove the six torx screws with the T4 torx screwdriver. Remove the six torx screws with the T4 torx screwdriver.
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. Place the plastic opening tool in the charging port. Pry up to loosen the bottom edge of the plastic mid frame. Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. 필수 도구 키트
    최고의 소형 키트에서 가장 유용한 도구.
    지금 쇼핑하기
    필수 도구 키트
    지금 쇼핑하기
  6. Locate the power button. Locate the volume botton.
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  7. Locate the power button sensor strip. Place the plastic opening tool under the sensor strip. Pry the sensor strip up.
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  8. Locate the volume button sensor strip. Place the plastic opening tool under the sensor strip. Pry the sensor strip up.
    • Locate the volume button sensor strip.
  9. Locate the outer screen connector. Place the plastic opening tool under the screen connector. Pry the screen connector up.
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  10. Locate the inner screen connector. Place the plastic opening tool under the screen connector. Pry the screen connector up.
    • Locate the inner screen connector.
  11. Place the plastic opening tool in the charger port. Pry the motherboard up. Remove the motherboard.
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  12. Pick up the front half of your phone with your left hand. Slowly rotate the phone so the screen falls into your right hand. Be extremely careful not to drop the screen.
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dillon
회원 가입일: 2014년 10월 23일
574 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-7, Lauer Fall 2014 Michigan Tech, Team 1-7, Lauer Fall 2014 회원
MTU-LAUER-F14S1G7
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 679
