주요 콘텐츠로 건너뛰기
T-Mobile REVVL Plus Battery Replacement
필요한 것
  1. T-Mobile REVVL Plus Battery Replacement, Removing the back: 1 단계, 이미지 2개 중 1개 T-Mobile REVVL Plus Battery Replacement, Removing the back: 1 단계, 이미지 2개 중 2개
    • The back of the phone is held on with a combination of plastic clips and adhesive.
    • The entry point is the speaker grille near the bottom of the phone. Be careful not to insert the opening tool directly downward to avoid damaging the speaker.
    • Insert a plastic opening tool in the hole in the back of the phone as shown to lift the back cover.
    • Insert a guitar pick to keep the plastic cover lifted.
  2. T-Mobile REVVL Plus Battery Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    • Work a guitar pick or opening tool around the edges of the back panel to disengage all clips.
    • There is adhesive around the edges of the back panel as well as around the camera.
    • The fingerprint sensor is attached to the back panel of the phone. Be careful not to rip the flex cable!
    • Insert the hook of a Halberd spudger into the small opening above the plastic part covering the fingerprint sensor and pry it off while covering it so it doesn't go flying away.
    • Disconnect the fingerprint sensor flex cable with the flat end of a Halberd spudger or an opening pick and set the back panel aside.
  3. T-Mobile REVVL Plus Battery Replacement, Removing the midframe: 3 단계, 이미지 3개 중 1개 T-Mobile REVVL Plus Battery Replacement, Removing the midframe: 3 단계, 이미지 3개 중 2개 T-Mobile REVVL Plus Battery Replacement, Removing the midframe: 3 단계, 이미지 3개 중 3개
    • Remove 10 black Philips screws (including one covered by a white sticker below the camera lens).
    • Remove 12 silver Philips screws.
    • Gently peel up the bottom half of the metal tape to reveal...
    • Two more black Philips screws to remove.
  4. T-Mobile REVVL Plus Battery Replacement: 4 단계, 이미지 1개 중 1개
    • The midframe is held on by strong plastic clips around the edges of the phone. Insert an opening tool or pick as shown near the SIM card slot
    • Ensure that all screws have been removed, then work your way around the edges of the phone.
    • Clips near the corners are particularly strong.
  5. T-Mobile REVVL Plus Battery Replacement, Remove the battery: 5 단계, 이미지 1개 중 1개
    • Disconnect the battery flex cable.
    • The battery is held in by 3 vertical strips of adhesive. Use rubbing alcohol and/or heat to soften the adhesive.
    • If you are replacing the screen, skip this step and remove the battery last.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Patrick
회원 가입일: 05/14/14
6,764 평판
안내서 21개를 작성함
1가이드 댓글
How do I change my charging port on my revel plus Coolpad
Brittney Adams - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 24
지난 30일: 138
전체 시간: 22,821
