주요 콘텐츠로 건너뛰기
T-Mobile SDA (HTC Tornado) Ear Speaker Replacement
필요한 것
  1. T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Battery: 1 단계, 이미지 1/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Battery: 1 단계, 이미지 2/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • To remove the battery cover, first turn the phone so that the keypad is face down.
    • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
    • Slide the battery cover toward the bottom of the phone to remove.
  2. T-Mobile SDA (HTC Tornado) Ear Speaker Replacement: 2 단계, 이미지 1/2 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement: 2 단계, 이미지 2/2
    • To remove the battery, first grab it using a finger on either side.
    • Pull the battery upward, while securing the phone with your other hand.
    • Gently remove the battery and place it to the side of the phone.
  3. T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Rear Phone Casing: 3 단계, 이미지 1/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Rear Phone Casing: 3 단계, 이미지 2/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Rear Phone Casing: 3 단계, 이미지 3/3
    • Move the battery and battery cover to the side and pick up the phone.
    • Use the plastic opening tool to remove the camera casing located at the top of the phone.
    • Use your fingers to pull out the gray antenna casing.
  4. T-Mobile SDA (HTC Tornado) Ear Speaker Replacement: 4 단계, 이미지 1/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement: 4 단계, 이미지 2/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement: 4 단계, 이미지 3/3
    • Hold the phone with one hand and the plastic opening tool with the other.
    • Pry the outer casing off of the phone by wedging the plastic opening tool between the casing and the phone, thus dislocating the tabs.
    • Place the outer casing to the side.
  5. T-Mobile SDA (HTC Tornado) Ear Speaker Replacement: 5 단계, 이미지 1/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement: 5 단계, 이미지 2/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement: 5 단계, 이미지 3/3
    • Using the T5 or T6 screwdriver, remove the six screws from the back of the phone, as shown in the first image.
    • Remove the back half of the phone by using the plastic opening tool to pry apart the top half from the bottom half. Wedge the plastic opening tool tool around the edge of the phone to dislocate the tabs.
    • Once the tabs are dislocated, pull the back of the phone apart from the front half.
  6. T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Circuit Board: 6 단계, 이미지 1/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Circuit Board: 6 단계, 이미지 2/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Circuit Board: 6 단계, 이미지 3/3
    • On the rear phone casing, locate the ribbon cable tab and connector next to the SIM card port.
    • Gently pull up on the tab to disconnect it from the connector.
    • Carefully remove the circuit board from the phone casing.
  7. T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Ear Speaker: 7 단계, 이미지 1/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Ear Speaker: 7 단계, 이미지 2/3 T-Mobile SDA (HTC Tornado) Ear Speaker Replacement, Ear Speaker: 7 단계, 이미지 3/3
    • Lay the front faceplate face down on a flat surface.
    • While holding the bottom of the faceplate with one hand, use the plastic opening tool to gently pry the ear speaker from the top of the phone.
    • Completely remove the speaker from the phone and set it to the side.
    • The serial number on the back of the speaker can be used to find the correct replacement speaker.
결론
John Miller
회원 가입일: 10/22/12
50 평판
안내서 4개 작성하였습니다
Clemson, Team 15-4, Benson Fall 2012 Clemson, Team 15-4, Benson Fall 2012 회원
CLEM-BENSON-F12S15G4
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 245
