주요 콘텐츠로 건너뛰기
T-Mobile SDA (HTC Tornado) SD Card Replacement
  1. T-Mobile SDA (HTC Tornado) SD Card Replacement, Battery: 1 단계, 이미지 1/3 T-Mobile SDA (HTC Tornado) SD Card Replacement, Battery: 1 단계, 이미지 2/3 T-Mobile SDA (HTC Tornado) SD Card Replacement, Battery: 1 단계, 이미지 3/3
    • To remove the battery cover, first turn the phone so that the keypad is face down.
    • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
    • Slide the battery cover toward the bottom of the phone to remove.
  2. T-Mobile SDA (HTC Tornado) SD Card Replacement: 2 단계, 이미지 1/2 T-Mobile SDA (HTC Tornado) SD Card Replacement: 2 단계, 이미지 2/2
    • To remove the battery, first grab it using a finger on either side.
    • Pull the battery upward, while securing the phone with your other hand.
    • Gently remove the battery and place it to the side of the phone.
  3. T-Mobile SDA (HTC Tornado) SD Card Replacement, SD Card: 3 단계, 이미지 1/1
    • Locate the slot for the SD card on the back of the phone. Insert the SD card so that the copper connectors on the card line up with the connectors on the phone (no card pictured).
  4. T-Mobile SDA (HTC Tornado) SD Card Replacement: 4 단계, 이미지 1/1
    • Secure the SD card in place by sliding the silver tab over it (SD card not pictured).
결론
Colin Horgan
회원 가입일: 10/22/12
32 평판
안내서 2개 작성하였습니다
Clemson, Team 15-4, Benson Fall 2012 Clemson, Team 15-4, Benson Fall 2012 회원
CLEM-BENSON-F12S15G4
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 257
