소개
This guide is useful if the SIM card of the phone needs to be replaced or removed.
도구
도구는 필요하지 않습니다.
부품
부품은 필요하지 않습니다.
  1. To remove the battery cover, first turn the phone so that the keypad is face down. While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover. Slide the battery cover toward the bottom of the phone to remove.
    • To remove the battery cover, first turn the phone so that the keypad is face down.
    • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
    • Slide the battery cover toward the bottom of the phone to remove.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. To remove the battery, first grab it using a finger on either side. Pull the battery upward, while securing the phone with your other hand.
    • To remove the battery, first grab it using a finger on either side.
    • Pull the battery upward, while securing the phone with your other hand.
    • Gently remove the battery and place it to the side of the phone.
  4. Open the SIM card door, located on the lower right part of the phone. Insert the SIM card into the door with the gold plating facing downward. Close the SIM card door by lightly pushing downward.
    • Open the SIM card door, located on the lower right part of the phone.
    • Insert the SIM card into the door with the gold plating facing downward.
    • Close the SIM card door by lightly pushing downward.
결론
Kaitlyn Patterson
회원 가입일: 2012년 10월 22일
45 평판
안내서 3개 작성하였습니다
Clemson, Team 15-4, Benson Fall 2012 Clemson, Team 15-4, Benson Fall 2012 회원
CLEM-BENSON-F12S15G4
4 회원들
안내서 10개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 308
