주요 콘텐츠로 건너뛰기
TC-WE825S Power Button Replacement
필요한 것
  1. TC-WE825S Power Button Replacement, TC-WE825S Power Button: 1 단계, 이미지 1/3 TC-WE825S Power Button Replacement, TC-WE825S Power Button: 1 단계, 이미지 2/3 TC-WE825S Power Button Replacement, TC-WE825S Power Button: 1 단계, 이미지 3/3
    • Unscrew the 8mm Phillips head screws from the left and right sides of the cassette player.
  2. TC-WE825S Power Button Replacement: 2 단계, 이미지 1/3 TC-WE825S Power Button Replacement: 2 단계, 이미지 2/3 TC-WE825S Power Button Replacement: 2 단계, 이미지 3/3
    • Unscrew the 8mm Phillips head screw from the back of the cassette panel. Remove the cover.
  3. TC-WE825S Power Button Replacement: 3 단계, 이미지 1/3 TC-WE825S Power Button Replacement: 3 단계, 이미지 2/3 TC-WE825S Power Button Replacement: 3 단계, 이미지 3/3
    • Locate the power cord connection and disconnect it. To remove it, press down on the plastic tab and slowly slide it out of the socket.
  4. TC-WE825S Power Button Replacement: 4 단계, 이미지 1/2 TC-WE825S Power Button Replacement: 4 단계, 이미지 2/2
    • Locate the cords that are connected to the power button. Remove the connection by tugging on the cords gently, releasing them from the main PC board.
  5. TC-WE825S Power Button Replacement: 5 단계, 이미지 1/1
    • Unscrew all five 7.5mm Phillips head screws from the PCB (printed circuit board) behind the power switch.
  6. TC-WE825S Power Button Replacement: 6 단계, 이미지 1/1
    • Use forceps to gently pry the PCB from the frame of the cassette player.
  7. TC-WE825S Power Button Replacement: 7 단계, 이미지 1/3 TC-WE825S Power Button Replacement: 7 단계, 이미지 2/3 TC-WE825S Power Button Replacement: 7 단계, 이미지 3/3
    • Use a soldering iron to desolder the power switch’s terminals and connections. Remove the power switch, replace it, and solder it back together. Repeat these steps in reverse order to put the cassette player back together.
결론
Cameron
회원 가입일: 06/01/16
108 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 610
