주요 콘텐츠로 건너뛰기
TCA PRC 152A Disassembly
필요한 것
  1. TCA PRC 152A Disassembly, Prepare the radio for dissasembly: 1 단계, 이미지 1개 중 1개
    • Remove antenna and battery before dissasembly
    • Prepare the tools before starting We'll start with the radio and then the accessories...
  2. TCA PRC 152A Disassembly, Removing the backpannel: 2 단계, 이미지 3개 중 1개 TCA PRC 152A Disassembly, Removing the backpannel: 2 단계, 이미지 3개 중 2개 TCA PRC 152A Disassembly, Removing the backpannel: 2 단계, 이미지 3개 중 3개
    • Remove 4 screws on the backpannel
    • Phillips PH3
    • The small retention piece is held by the screw. Be careful not to lose the spring
  3. TCA PRC 152A Disassembly, Removing the backpanel: 3 단계, 이미지 2개 중 1개 TCA PRC 152A Disassembly, Removing the backpanel: 3 단계, 이미지 2개 중 2개
    • Carefully open the rear panel with the opener's plastic tool.
    • You can see the connection map of the different terminals.
    • GPS option (Does not work)
    • PTT and config button socket
    • U283 6PIN connector
    • ON/OFF/Volume knob
    • Side connector (Does not work)
  4. TCA PRC 152A Disassembly, Removing frontpannel: 4 단계, 이미지 3개 중 1개 TCA PRC 152A Disassembly, Removing frontpannel: 4 단계, 이미지 3개 중 2개 TCA PRC 152A Disassembly, Removing frontpannel: 4 단계, 이미지 3개 중 3개
    • Carefully open the front panel with the opener's plastic tool.
    • Microphone attached to the PCB board (1.080KOhm).Can be replaced by POW-2744P-B-R
    • Speaker FCE 16Ohm 1Watt.
    • Beware of silicone for the sealing of the elements.
  5. TCA PRC 152A Disassembly, Frontpannel microphone removal: 5 단계, 이미지 3개 중 1개 TCA PRC 152A Disassembly, Frontpannel microphone removal: 5 단계, 이미지 3개 중 2개 TCA PRC 152A Disassembly, Frontpannel microphone removal: 5 단계, 이미지 3개 중 3개
    • Remove 1 screw
    • Phillips PH1
    • Carefully remove withe the plastic tool
  6. TCA PRC 152A Disassembly, Display and keyboard front card: 6 단계, 이미지 3개 중 1개 TCA PRC 152A Disassembly, Display and keyboard front card: 6 단계, 이미지 3개 중 2개 TCA PRC 152A Disassembly, Display and keyboard front card: 6 단계, 이미지 3개 중 3개
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the flat connector
    • Use caution when you remove the flat connector
  7. TCA PRC 152A Disassembly, Display and keyboard front card: 7 단계, 이미지 2개 중 1개 TCA PRC 152A Disassembly, Display and keyboard front card: 7 단계, 이미지 2개 중 2개
    • Place the electronics elements on ESD bags
  8. TCA PRC 152A Disassembly, Peripheral back card: 8 단계, 이미지 3개 중 1개 TCA PRC 152A Disassembly, Peripheral back card: 8 단계, 이미지 3개 중 2개 TCA PRC 152A Disassembly, Peripheral back card: 8 단계, 이미지 3개 중 3개
    • Disconnect 2 JSP connectors and 2 flat connector
    • Remove 4 screws
    • Phillips PH2
    • Carefully disconect the connectors and the board
  9. TCA PRC 152A Disassembly, Mainboard removal: 9 단계, 이미지 3개 중 1개 TCA PRC 152A Disassembly, Mainboard removal: 9 단계, 이미지 3개 중 2개 TCA PRC 152A Disassembly, Mainboard removal: 9 단계, 이미지 3개 중 3개
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the antenna connector
    • Carefully removing the mainboard
    • Thermal paste between the card and the body
  10. TCA PRC 152A Disassembly, Side connectors removal: 10 단계, 이미지 2개 중 1개 TCA PRC 152A Disassembly, Side connectors removal: 10 단계, 이미지 2개 중 2개
    • Remove 2 screws
    • Phillips PH1
    • Carefully removing the connector
  11. TCA PRC 152A Disassembly, Batterybloc dissasembly: 11 단계, 이미지 3개 중 1개 TCA PRC 152A Disassembly, Batterybloc dissasembly: 11 단계, 이미지 3개 중 2개 TCA PRC 152A Disassembly, Batterybloc dissasembly: 11 단계, 이미지 3개 중 3개
    • Remove 2 screws
    • Phillips PH3
    • Remove the topcover, take care about short circuit
  12. TCA PRC 152A Disassembly, Batterybloc dissasembly: 12 단계, 이미지 3개 중 1개 TCA PRC 152A Disassembly, Batterybloc dissasembly: 12 단계, 이미지 3개 중 2개 TCA PRC 152A Disassembly, Batterybloc dissasembly: 12 단계, 이미지 3개 중 3개
    • Remove battery stick (18650 Panasonic)
    • Remove 2 screws
    • Phillips PH3
    • Take off the inner white retainer
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tomazo_88
회원 가입일: 06/09/20
409 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 63
전체 시간: 4,275
