주요 콘텐츠로 건너뛰기
TCA Quadrant Calibration
    • If you have your Quadrant plugged-in, then unplug it.
  1. TCA Quadrant Calibration, Lower all levers: 2 단계, 이미지 2개 중 1개 TCA Quadrant Calibration, Lower all levers: 2 단계, 이미지 2개 중 2개
    • Mover each of the 3 levers to the lowest position.
  2. TCA Quadrant Calibration, Press and Hold the Indicated button.: 3 단계, 이미지 1개 중 1개
    • Press and hold the button highlighted.
  3. TCA Quadrant Calibration, Plug to USB port While holding the button.: 4 단계, 이미지 1개 중 1개
    • Connect your Quadrant to USB port while still holding the button.
    • Once connected, wait a few seconds and let go of the button
    • You can connect to:
    • USB port of your PC.
    • USB Port at the back of your TCA Yoke.
    • USB port of your Xbox.
    • Do not use USB Hubs or extension cables.
  4. TCA Quadrant Calibration, Move all levers up: 5 단계, 이미지 2개 중 1개 TCA Quadrant Calibration, Move all levers up: 5 단계, 이미지 2개 중 2개
    • Pull each levers to the highest position.
    • Move the levers smoothly for better calibration.
  5. TCA Quadrant Calibration, Press the Indicated buttons: 6 단계, 이미지 1개 중 1개
    • Press these 2 buttons at the same time.
    • This should save the calibration.
결승점
작성자
1다른 기여자 명과 함께
Formica Fusca
회원 가입일: 08/01/24
2,595 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 23
전체 시간: 344
