주요 콘텐츠로 건너뛰기
TCA Quadrant Flash and re-install the firmware
필요한 것
    • Download and install the driver package from here.
    • Both the Sidestick and the Quadrant are using the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your Quadrant from USB if you already have it plugged-in
  1. TCA Quadrant Flash and re-install the firmware, Press and hold the indicated button.: 4 단계, 이미지 1개 중 1개
    • Press and hold the button highlighted in the image.
    • Keep holding the button and connect the Quadrant directly to USB port of your PC.
    • Connection must go directly to USB port of your PC and not through the Sidestick
    • Your Quadrant should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
결승점
작성자
1다른 기여자 명과 함께
Formica Fusca
회원 가입일: 08/01/24
2,595 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 41
전체 시간: 370
