주요 콘텐츠로 건너뛰기
TCA Yoke Calibration
    • If you have your Yoke plugged-in, then unplug it.
    • Set the switch at the back of the Yoke to PC position.
    • If you are using Xbox, you still need to set the switch to PC position.
    • Don't forget to switch it back to Xbox, once you have completed this guide.
    • Make sure that Roll and Pitch are at resting point.
    • Make sure the right mini-stick is at resting point.
    • Make sure that Throttles are in the middle
    • Throttles don't have to be in the exact middle.
  1. TCA Yoke Calibration, Press and hold the indicated buttons: 4 단계, 이미지 1개 중 1개
    • Press and hold the buttons highlighted in the image
    • Connect the Yoke to USB port while holding the buttons.
    • Once the Xbox button starts flashing, release the buttons.
  2. TCA Yoke Calibration, Press XBOX button: 6 단계, 이미지 1개 중 1개
    • Press on the Xbox button.
    • It should start flashing faster.
  3. TCA Yoke Calibration, Move the Yoke all the way to the right.: 7 단계, 이미지 1개 중 1개
    • Move the Yoke to the right, until you reach maximum.
    • Return the Yoke to Center.
    • For better results, move it smoothly, without forcing.
  4. TCA Yoke Calibration, Move the Yoke all the way to the left.: 8 단계, 이미지 1개 중 1개
    • Move the Yoke to the left, until you reach maximum.
  5. TCA Yoke Calibration, Push the Yoke forward: 9 단계, 이미지 1개 중 1개
    • Push the Yoke forward, until you reach maximum.
    • Make sure to not accidentally move yoke Left or Right.
  6. TCA Yoke Calibration, Pull the Yoke backwards: 10 단계, 이미지 1개 중 1개
    • Pull the Yoke towards yourself, until you reach maximum.
  7. TCA Yoke Calibration, Move the mini-stick to the right: 11 단계, 이미지 1개 중 1개
    • Move the mini-stick to the right, until you reach maximum.
    • Return the mini-stick to Center.
  8. TCA Yoke Calibration, Move the mini-stick to the left.: 12 단계, 이미지 1개 중 1개
    • Move the mini-stick to the left, until you reach maximum.
  9. TCA Yoke Calibration, Move the mini-stick up: 13 단계, 이미지 1개 중 1개
    • Move the mini-stick up, until you reach maximum.
  10. TCA Yoke Calibration, Move mini-stick down: 14 단계, 이미지 1개 중 1개
    • Move the mini-stick down, until you reach maximum.
  11. TCA Yoke Calibration, Move both Throttles down: 15 단계, 이미지 1개 중 1개
    • Move both throttles down, until you reach maximum.
  12. TCA Yoke Calibration, Move throttles up: 16 단계, 이미지 1개 중 1개
    • Move both throttles up, until you reach maximum.
  13. TCA Yoke Calibration, Press XBOX button: 17 단계, 이미지 1개 중 1개
    • Press Xbox button to finish the calibration.
    • Xbox button should stop flashing.
    • Make sure that Yoke, Throttles and mini-sticks have been returned to neutral positions.
결승점
작성자
1다른 기여자 명과 함께
Formica Fusca
회원 가입일: 08/01/24
2,595 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 83
전체 시간: 917
