주요 콘텐츠로 건너뛰기
TCL Stylus Battery Replacement
필요한 것
    • Press and hold the Power button for 2 seconds.
    • Then, select "Power off".
  1. TCL Stylus Battery Replacement, Remove back panel: 2 단계, 이미지 3개 중 1개 TCL Stylus Battery Replacement, Remove back panel: 2 단계, 이미지 3개 중 2개 TCL Stylus Battery Replacement, Remove back panel: 2 단계, 이미지 3개 중 3개
    • Insert a jimmy tool into the casing to create a gap.
    • Then, put a plastic pick in the gap and remove the jimmy tool.
    • Finally, lift up to remove the panel.
  2. TCL Stylus Battery Replacement, Remove plastic shielding: 3 단계, 이미지 2개 중 1개 TCL Stylus Battery Replacement, Remove plastic shielding: 3 단계, 이미지 2개 중 2개
    • Remove the 10 Phillips screws holding the plastic shielding from the motherboard.
    • Then, grab a pick and put in in the slot show on picture 2.
    • You should then be able to lift the rest of it off.
  3. TCL Stylus Battery Replacement, Unplug battery: 4 단계, 이미지 2개 중 1개 TCL Stylus Battery Replacement, Unplug battery: 4 단계, 이미지 2개 중 2개
    • With your fingernail, lift up the battery connector.
  4. TCL Stylus Battery Replacement, Unpeel tape: 5 단계, 이미지 2개 중 1개 TCL Stylus Battery Replacement, Unpeel tape: 5 단계, 이미지 2개 중 2개
    • Unpeel the tape holding the battery.
  5. TCL Stylus Battery Replacement, Remove battery: 6 단계, 이미지 2개 중 1개 TCL Stylus Battery Replacement, Remove battery: 6 단계, 이미지 2개 중 2개
    • Pull on the sticker located on the middle of the left side (colored green) of the battery to remove it.
    • NOTE: The pull tab may have resistance.
결론
작성자
1다른 기여자 명과 함께
Lee Hunt
회원 가입일: 12/08/16
1,276 평판
안내서 7개를 작성함
5가이드 댓글
Lg syluis is a non removeable battery
katherine hicks - 답글
It's just not easily removable. But every battery in every phone is removable if you know what you're doing. That's why the pictures explain. You come in here getting all worked up but your ignorance really shows. Obviously you don't have the intelligence to attempt this kind of repair, so go crochet me some mittens or something.
Cj Gabbard -
Its a non removeable battery phone,unless u control it with a chiness &&^&@@ dumb ass move battery
Thanks for the information. At least you do not have to deal with heating the phone in order to loosen adhesive which is common with other phone models. Six steps to get to the battery is way easier than going through over 20 steps to do the same thing.
e s - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 35
전체 시간: 2,267
