주요 콘텐츠로 건너뛰기
TCL Stylus Entering Recovery Mode
  1. TCL Stylus Entering Recovery Mode, TCL Stylus Entering Recovery Mode: 1 단계, 이미지 2개 중 1개 TCL Stylus Entering Recovery Mode, TCL Stylus Entering Recovery Mode: 1 단계, 이미지 2개 중 2개
    • Turn off the phone.
    • Press and hold the Power key until you see a menu, then press "Power off".
    • Wait until the TCL logo disappears and the vibration is done.
  2. TCL Stylus Entering Recovery Mode: 2 단계, 이미지 1개 중 1개
    • Press Volume Up and Power until the TCL logo appears.
    • Once the TCL logo appears, let go.
  3. TCL Stylus Entering Recovery Mode: 3 단계, 이미지 1개 중 1개
    • You are now in recovery mode, you can reset the phone from here. Touch is disabled in recovery mode on the TCL Stylus.
    • To navigate, use Volume Up/Down to navigate between options, and press Power to select.
결론
Done!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Lee Hunt
회원 가입일: 12/08/16
1,276 평판
안내서 7개를 작성함
1가이드 댓글
My stylus has black screen but shows batt charging but won't come on won't reset using power keys and volume keys tried sticking some in the pin holes that didn't work either help next. Step disassemble
Ronald Walker - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 25
전체 시간: 1,277
