주요 콘텐츠로 건너뛰기
TDK Life on Record A26 Battery Replacement
필요한 것
  1. TDK Life on Record A26 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Get a replacement battery from the TDK company. The battery part number is E23-00059-01.
  2. TDK Life on Record A26 Battery Replacement: 2 단계, 이미지 1/2 TDK Life on Record A26 Battery Replacement: 2 단계, 이미지 2/2
    • Obtain the screwdriver and the T09 (Torx) bit from the iFixit toolkit and assemble them together.
  3. TDK Life on Record A26 Battery Replacement: 3 단계, 이미지 1/2 TDK Life on Record A26 Battery Replacement: 3 단계, 이미지 2/2
    • Use the T09-bit screwdriver to remove the two 8-mm torx screws on the bottom strip of the speaker.
  4. TDK Life on Record A26 Battery Replacement: 4 단계, 이미지 1/3 TDK Life on Record A26 Battery Replacement: 4 단계, 이미지 2/3 TDK Life on Record A26 Battery Replacement: 4 단계, 이미지 3/3
    • Remove the faceplate by using the pointy side of the black plastic spudger.
    • Stick the point of the spudger into one of the corners surrounding the faceplate and gently pull it up.
  5. TDK Life on Record A26 Battery Replacement: 5 단계, 이미지 1/1
    • Then exchange the T09 bit for a PH1 bit
  6. TDK Life on Record A26 Battery Replacement: 6 단계, 이미지 1/2 TDK Life on Record A26 Battery Replacement: 6 단계, 이미지 2/2
    • Use the PH1-bit screwdriver to remove the eight 11-mm Phillips head screws that are located behind the faceplate.
  7. TDK Life on Record A26 Battery Replacement: 7 단계, 이미지 1/2 TDK Life on Record A26 Battery Replacement: 7 단계, 이미지 2/2
    • Remove the one 7-mm Phillips head screw located on the lower left of the front of the speaker with the PH1-bit screwdriver.
  8. TDK Life on Record A26 Battery Replacement: 8 단계, 이미지 1/2 TDK Life on Record A26 Battery Replacement: 8 단계, 이미지 2/2
    • After all screws are removed, turn the speaker over to the back of the speaker.
  9. TDK Life on Record A26 Battery Replacement: 9 단계, 이미지 1/3 TDK Life on Record A26 Battery Replacement: 9 단계, 이미지 2/3 TDK Life on Record A26 Battery Replacement: 9 단계, 이미지 3/3
    • Use the blue plastic opening tool from the toolkit to pry off the back of the speaker, gradually moving around the device.
    • Make sure to open it evenly on all sides.
  10. TDK Life on Record A26 Battery Replacement: 10 단계, 이미지 1/2 TDK Life on Record A26 Battery Replacement: 10 단계, 이미지 2/2
    • Then remove the bottom narrow strip of plastic to uncover the battery.
  11. TDK Life on Record A26 Battery Replacement: 11 단계, 이미지 1/2 TDK Life on Record A26 Battery Replacement: 11 단계, 이미지 2/2
    • Follow the red, black, and white wires attached to the green battery sleeve down to the white small plug.
  12. TDK Life on Record A26 Battery Replacement: 12 단계, 이미지 1/2 TDK Life on Record A26 Battery Replacement: 12 단계, 이미지 2/2
    • Once you have found the white plug, gently grip the colored wires and carefully pull to remove the white plug from the speaker.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Elise Howard
회원 가입일: 10/13/15
831 평판
안내서 3개 작성하였습니다
Sam Houston State, Team 2-2, Blackburne Fall 2015 Sam Houston State, Team 2-2, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G2
3 회원들
안내서 3개 작성하였습니다
댓글 2개
This procedure is totally unnecessary! TDK has much simpler instructions. http://downloads.imationsupport.com/lor/...
Marty F - 답글
Actually, this page DID help me as the other “simpler” instrucions didn’t work, as I was unable to slide the battery cover after removing the two screws.In any case the entire procedure only took about ten minutes, so THANK YOU!
Sander - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 31
전체 시간: 7,042
