주요 콘텐츠로 건너뛰기
TDK Life on Record A26 Front Faceplate Replacement
필요한 것
  1. TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: 1 단계, 이미지 1/2 TDK Life on Record A26 Front Faceplate Replacement, Front Faceplate: 1 단계, 이미지 2/2
    • Obtain the black plastic spudger to remove the faceplate.
    • Insert the pointed end of the tool inside one of the holes on the faceplate itself.
    • The corner is the best place to start.
    • The faceplate has many little holes so choose one that makes it easier for you.
  2. TDK Life on Record A26 Front Faceplate Replacement: 2 단계, 이미지 1/3 TDK Life on Record A26 Front Faceplate Replacement: 2 단계, 이미지 2/3 TDK Life on Record A26 Front Faceplate Replacement: 2 단계, 이미지 3/3
    • Gently start to lift until the faceplate starts to rise.
    • If you are having trouble getting the faceplate off, continue trying on the rest of the corners until fully removed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Elise Howard
회원 가입일: 10/13/15
831 평판
안내서 3개 작성하였습니다
Sam Houston State, Team 2-2, Blackburne Fall 2015 Sam Houston State, Team 2-2, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G2
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 482
