소개
Replacing the battery is a fairly straightforward and easy process, which may need to be done if the device isn't charging or isn't turning on. A replacement battery, which can be obtained from the TDK website, is needed, along with a Torx screwdriver. Be gentle when working around the wires, as they are fairly thin and can break easily. Overall, this is an easy fix which almost anyone can do.
필요한 것
Remove all (6) 5mm Torx (Star) screws on the bottom panel of the device using the T4 screwdriver.
Disconnect the old battery from the plug that is attached to the device by grabbing both ends of the plug and pulling them apart.
다른 20명이 해당 안내서를 완성하였습니다.
댓글 5개
This was a GREAT tutorial.
I did find on step 3 that I could not dislodge the cover with my fingernails. I had to use a jeweler's screwdriver to carefully pry it loose. I also found that it was easier to put the new battery in flat end first and then laying it down and putting the wires into the pocket.
Thanks for sharing.
Beautifully done, 5 star
Use the T5 Not T4
