주요 콘텐츠로 건너뛰기
TDK Life on Record A33 Control Pad Replacement
필요한 것
  1. TDK Life on Record A33 Control Pad Replacement, Control Pad: 1 단계, 이미지 1개 중 1개
    • Push the nylon or metal spudger under the corner of the control pad. This might take some patience, but it gets easier once the spudger gets under the control pad.
  2. TDK Life on Record A33 Control Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the nylon or metal spudger along the long edge of the control panel, up to the next edge.
    • This may need to be done several times to get the control pad loose enough to come off. If needed, it can be done on more than just one edge, especially if you're having trouble picking up the edge in the next step.
  3. TDK Life on Record A33 Control Pad Replacement: 3 단계, 이미지 2개 중 1개 TDK Life on Record A33 Control Pad Replacement: 3 단계, 이미지 2개 중 2개
    • Grab the corner of the control pad and peel it off slowly. You should be able to see the circuit board.
    • When replacing the control pad, the glue that is on the speaker should be able to hold the control pad. However, glue can be used if it is not sticking well enough. Make sure the glue does not get on the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matthew Festa
회원 가입일: 10/16/15
808 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-2, Catania Fall 2015 UMass Dartmouth, Team 4-2, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 5,075
