주요 콘텐츠로 건너뛰기
TDK Life on Record A33 Speaker Replacement
필요한 것
  1. TDK Life on Record A33 Speaker Replacement, Speaker Guard: 1 단계, 이미지 1개 중 1개
    • Push the nylon or metal spudger in the corner of the speaker guard.
  2. TDK Life on Record A33 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Slowly lift the speaker up enough so that you can slide around the speaker guard.
  3. TDK Life on Record A33 Speaker Replacement: 3 단계, 이미지 2개 중 1개 TDK Life on Record A33 Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the nylon or metal spudger all around the speaker guard.
  4. TDK Life on Record A33 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the speaker guard. You can now replace the speaker guard on your TDK Life on Record A33.
  5. TDK Life on Record A33 Speaker Replacement, Speaker: 5 단계, 이미지 2개 중 1개 TDK Life on Record A33 Speaker Replacement, Speaker: 5 단계, 이미지 2개 중 2개
    • Remove all (4) 3mm screws in the middle speaker using a Phillip's head screwdriver.
    • You can also remove the speakers on the left and right.
  6. TDK Life on Record A33 Speaker Replacement: 6 단계, 이미지 2개 중 1개 TDK Life on Record A33 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Do not rip the wires inside the speaker when trying to open the middle speaker on the device.
    • Create an opening in the speaker by holding the device up and carefully grabbing the side of the speaker that pops out.
  7. TDK Life on Record A33 Speaker Replacement: 7 단계, 이미지 2개 중 1개 TDK Life on Record A33 Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Wear safety goggles and have something to absorb the smoke from the soldering iron just in case.
    • Do not burn the wires of the speaker.
    • Remove the solder that connects the wires to the speaker. You should be able to now remove the speaker and replace it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matthew Phou
회원 가입일: 10/20/15
448 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-2, Catania Fall 2015 UMass Dartmouth, Team 4-2, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G2
4 회원들
안내서 5개를 작성함
댓글 3개
Where can I buy the woofer?
stevealvarado54 - 답글
Really, stevealvarado! What's The point of taking this all apart if you don't have a replacement to put in?
Van Moon - 답글
If l need a second opinion about which speaker is blown, who or where can can l get it diagnosed?
Tony - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 16
전체 시간: 4,586
