주요 콘텐츠로 건너뛰기
TDK Life on Record Trek 360 Air Vent Tube Replacement
필요한 것
  1. TDK Life on Record Trek 360 Air Vent Tube Replacement, Disassembling TDK Life on Record bottom panel: 1 단계, 이미지 1/1
    • Remove the four rubber feet of the device using a metal spudger.
  2. TDK Life on Record Trek 360 Air Vent Tube Replacement: 2 단계, 이미지 1/2 TDK Life on Record Trek 360 Air Vent Tube Replacement: 2 단계, 이미지 2/2
    • Remove the four 9 mm Phillips #0 screws located under the feet of the device.
    • Remove the four 9 mm Torx #8 screws located on each side of the bottom the device.
  3. TDK Life on Record Trek 360 Air Vent Tube Replacement: 3 단계, 이미지 1/2 TDK Life on Record Trek 360 Air Vent Tube Replacement: 3 단계, 이미지 2/2
    • Pull the bottom cover of the device towards you.
  4. TDK Life on Record Trek 360 Air Vent Tube Replacement: 4 단계, 이미지 1/2 TDK Life on Record Trek 360 Air Vent Tube Replacement: 4 단계, 이미지 2/2
    • Remove the four 13 mm Phillips #1 screws.
  5. TDK Life on Record Trek 360 Air Vent Tube Replacement: 5 단계, 이미지 1/2 TDK Life on Record Trek 360 Air Vent Tube Replacement: 5 단계, 이미지 2/2
    • Use one hand to grip the device from the side of the handle, and use the other hand to grip the side of the device that contains the woofer
    • The woofer is the circular component located at the bottom of the device after the bottom cover has been removed
    • Pull apart the compartments by applying force in opposite directions.
    • Do not pull with extreme force!! There are many electrical wires inside the device that can become damaged if the bottom panel is removed without care
  6. TDK Life on Record Trek 360 Air Vent Tube Replacement: 6 단계, 이미지 1/1
    • Disconnect the seven cables attached to the motherboard.
    • Do not use too much force when pulling on the wires. Pulling with too much force can damage the wires.
  7. TDK Life on Record Trek 360 Air Vent Tube Replacement, Air Vent Tube: 7 단계, 이미지 1/1
    • Remove the four 8 mm Phillips #1 screws.
  8. TDK Life on Record Trek 360 Air Vent Tube Replacement: 8 단계, 이미지 1/3 TDK Life on Record Trek 360 Air Vent Tube Replacement: 8 단계, 이미지 2/3 TDK Life on Record Trek 360 Air Vent Tube Replacement: 8 단계, 이미지 3/3
    • place your hands on each side of the air vent and then place your index finger on the thin plastic half circle that holds the vent in place.
    • Pull the plastic half circle towards you.
    • Put both of your hands inside the tube as shown and push away from you.
결론
Helen Huynh
회원 가입일: 09/14/15
338 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 1-2, Bruce Fall 2015 CSU Fullerton, Team 1-2, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Where can I get a new motherboard?
american1gigolo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 711
