소개
This guide will aid you in replacing your old or worn out battery. Replacing the battery will also increase usage time and enhance all other functions of the device.
필요한 것
Turn the TDK Life on Record Trek 360 on its side as shown and remove the four 8 mm screws holding the battery cover in place with the T-5 torx screw bit.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Good guide, but what battery fits?
I have opened the hatch but I can’t lift the battery out. My battery seems to be glued in place…. :(
EDIT: I broke several cheap plastic spudgers, but when I finally used a metallic one, the battery pack came right out. Yes, I read that one shouldn’t use a metallic one, but this battery is dead like the dodo anyway.
