주요 콘텐츠로 건너뛰기
TDK Life on Record Trek Max A34 Battery Replacement
필요한 것
  1. TDK Life on Record Trek Max A34 Battery  Replacement, Battery: 1 단계, 이미지 1/2 TDK Life on Record Trek Max A34 Battery  Replacement, Battery: 1 단계, 이미지 2/2
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Battery  Replacement: 2 단계, 이미지 1/2 TDK Life on Record Trek Max A34 Battery  Replacement: 2 단계, 이미지 2/2
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Battery  Replacement: 3 단계, 이미지 1/3 TDK Life on Record Trek Max A34 Battery  Replacement: 3 단계, 이미지 2/3 TDK Life on Record Trek Max A34 Battery  Replacement: 3 단계, 이미지 3/3
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Battery  Replacement: 4 단계, 이미지 1/2 TDK Life on Record Trek Max A34 Battery  Replacement: 4 단계, 이미지 2/2
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Battery  Replacement: 5 단계, 이미지 1/1
    • The battery is now separated from the device and may be replaced with a new battery.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Kayla
회원 가입일: 09/28/15
315 평판
안내서 1개 작성함
Texas Tech, Team 19-3, Rauch Fall 2015 Texas Tech, Team 19-3, Rauch Fall 2015 회원
TTU-RAUCH-F15S19G3
4 회원들
안내서 1개 작성하였습니다
댓글 2개
This post is incorrect on the size of the Torx driver! I literally just got done replacing an A34 battery and the T-7 is too large! A T-6 driver is required!
John Johnston - 답글
my problem of my trek max unit
everytime recharge my trek max is hot.
Wilfredo Natividad - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 33
전체 시간: 11,180
