주요 콘텐츠로 건너뛰기
TI-84 Plus Silver Edition Backup Battery Replacement
필요한 것
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: 1 단계, 이미지 3개 중 1개 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: 1 단계, 이미지 3개 중 2개 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: 1 단계, 이미지 3개 중 3개
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
    Removing these batteries and the back up battery will clear the calculators memory.
    Aaron Rueppel - 답글
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: 3 단계, 이미지 1개 중 1개
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: 5 단계, 이미지 2개 중 1개 TI-84 Plus Silver Edition Backup Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
    • Push gently downward until the backup battery pops out.
결론
다른 17명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Agustin
회원 가입일: 10/20/13
1,035 평판
안내서 2개를 작성함
Cal Poly, Team 11-34, Amido Fall 2013 Cal Poly, Team 11-34, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G34
4 회원들
안내서 6개를 작성함
댓글 9개
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - 답글
Because it's a completely different calculator.
Ozan Munsuz -
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - 답글
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - 답글
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel -
The TI-84 calculator backup button battery is a size 303 or SR44SW.
speedyfingers - 답글
this didi’t work i have replaced both back up and main batteries
Michael Rubio - 답글
This little button battery was insanely difficult to remove (and replace). It required me to deform my cheap plastic pry tool. Definitely poor design there from TI.
David P - 답글
If the backup battery is dead and I remove it do I have to replace it before the calculator will turn on?
Taylor Sullivan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 62
지난 30일: 216
전체 시간: 68,342
