주요 콘텐츠로 건너뛰기
TI-84 Plus Silver Edition Battery Spring Replacement
필요한 것
  1. TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: 1 단계, 이미지 2개 중 1개 TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: 1 단계, 이미지 2개 중 2개
    • Unscrew all six 8.5mm screws in the back of the calculator using the T6 star screw bit.
  2. TI-84 Plus Silver Edition Battery Spring Replacement: 2 단계, 이미지 2개 중 1개 TI-84 Plus Silver Edition Battery Spring Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry the calculator open.
    • Use your hands to firmly grasp and pull apart the calculator when a reasonable gap has been made.
  3. TI-84 Plus Silver Edition Battery Spring Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery in order to access the battery spring that needs to be replaced.
  4. TI-84 Plus Silver Edition Battery Spring Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the damaged spring using the tweezers.
  5. TI-84 Plus Silver Edition Battery Spring Replacement: 5 단계, 이미지 2개 중 1개 TI-84 Plus Silver Edition Battery Spring Replacement: 5 단계, 이미지 2개 중 2개
    • Pick up the new spring with the tweezers.
    • Insert the new spring with the tweezers.
    • Gently push the new spring into place using your finger.
  6. TI-84 Plus Silver Edition Battery Spring Replacement: 6 단계, 이미지 1개 중 1개
    • Test by replacing the battery that was taken out to check the connection.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Clayton Rudolph
회원 가입일: 09/15/20
157 평판
안내서 1개를 작성함
2가이드 댓글
Hi! So where can I get the spring part?
Aleyson B.Hunter - 답글
Hey! You can make a fix by bending a bit of stripped copper wire. I uploaded some Images of my fix, it worked reliably you just had to be careful when replacing batteries.
However i have found my original spring. But whiles searing for one to buy i stumble on many on Aliexpress that you could bend to the correct shape, Maybe this FW-DCTHZ9X20 (Seller) would work as the end part of the original spring is as well 9 mm.
Julian Lundh -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 27
전체 시간: 1,006
