주요 콘텐츠로 건너뛰기
TI-84 Plus Silver Edition Faceplate Replacement
  1. TI-84 Plus Silver Edition Faceplate Replacement, Faceplate: 1 단계, 이미지 1개 중 1개
    • Insert your index finger in the open slot below the keys.
    • Be careful to not bend the plate too much because it is very thin and might break.
    • Apply a firm upward force until the bottom two tabs located near the bottom of the plate come off.
  2. TI-84 Plus Silver Edition Faceplate Replacement: 2 단계, 이미지 1개 중 1개
    • Grab the face plate on each side near the middle and apply a gentle upward force on each side until the middle tabs come off.
    • A tab is located in the center of the face plate. If it is still attached, then continue to apply a gentle upward force until the center tab comes off.
    • Lift the face plate upward until the top three tabs come off and the face plate is completely detached.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Agustin
회원 가입일: 10/20/13
1,041 평판
안내서 2개를 작성함
Cal Poly, Team 11-34, Amido Fall 2013 Cal Poly, Team 11-34, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G34
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 21
전체 시간: 10,633
