주요 콘텐츠로 건너뛰기
소개
This guide shows the step by step process of how to disassemble a TI-89 Titanium calculator in order to replace the power button. This guide may also be followed in order to replace any of the other buttons on the calculator. This process requires few tools and should only take thirty minutes. Please be careful during the disassembly to not damage the internals of the calculator.
  1. TI-89 Titanium Power Button Replacement, Power Button: step 1, image 1 of 1
    • Remove the six T6 screws from the back of the calculator.
  2. TI-89 Titanium Power Button Replacement: step 2, image 1 of 1
    • Remove the battery cover.
  3. TI-89 Titanium Power Button Replacement: step 3, image 1 of 1
    • Unscrew the Phillips screw on the internal battery cover.
  4. TI-89 Titanium Power Button Replacement: step 4, image 1 of 1
    • Using a spudger or similar prying tool carefully pop the back of the calculator off.
  5. TI-89 Titanium Power Button Replacement: step 5, image 1 of 1
    • Remove the back of the calculator.
  6. TI-89 Titanium Power Button Replacement: step 6, image 1 of 1
    • Remove the six Phillips head screws from the circuit board.
    Mine also had a aluminum shielding. No particular impact on the repair. ust removed it by unscrewing two lower screws.
    Martin Olsson - 답글
  7. TI-89 Titanium Power Button Replacement: step 7, image 1 of 1
    • Remove the circuit board and the attached display screen. Make sure not to damage the circuit board.
    It would be great if you always included a high res photo of the circuit board of both sides. I don’t usually repair my products, but I come to iFixit often to know what the inside of my devices looks like.
    rtourn - 답글
  8. TI-89 Titanium Power Button Replacement: step 8, image 1 of 1
    • Peel back the rubber grommet sheet.
    • Make sure that the buttons remain attached the the rubber grommet as you remove it.
  9. TI-89 Titanium Power Button Replacement: step 9, image 1 of 1
    • Remove and replace the On button.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dan Stahl
회원 가입일: 2017년 10월 01일
156 평판
안내서 1개 작성함
Michigan Tech, Team S5-G3, Galliah Fall 2017 Michigan Tech, Team S5-G3, Galliah Fall 2017 회원
MTU-GALLIAH-F17S5G3
3 회원들
안내서 1개 작성하였습니다
댓글 한 개
Thank you, fixed my sticky keys / juice spill damage.
Martin Olsson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 72
전체 시간: 2,367
