주요 콘텐츠로 건너뛰기
TI-89 Titanium Power Button Replacement
필요한 것
  1. TI-89 Titanium Power Button Replacement, Power Button: 1 단계, 이미지 1/1
    • Remove the six T6 screws from the back of the calculator.
  2. TI-89 Titanium Power Button Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover.
  3. TI-89 Titanium Power Button Replacement: 3 단계, 이미지 1/1
    • Unscrew the Phillips screw on the internal battery cover.
  4. TI-89 Titanium Power Button Replacement: 4 단계, 이미지 1/1
    • Using a spudger or similar prying tool carefully pop the back of the calculator off.
  5. TI-89 Titanium Power Button Replacement: 5 단계, 이미지 1/1
    • Remove the back of the calculator.
  6. TI-89 Titanium Power Button Replacement: 6 단계, 이미지 1/1
    • Remove the six Phillips head screws from the circuit board.
    Mine also had a aluminum shielding. No particular impact on the repair. ust removed it by unscrewing two lower screws.
    Martin Olsson - 답글
  7. TI-89 Titanium Power Button Replacement: 7 단계, 이미지 1/1
    • Remove the circuit board and the attached display screen. Make sure not to damage the circuit board.
    It would be great if you always included a high res photo of the circuit board of both sides. I don’t usually repair my products, but I come to iFixit often to know what the inside of my devices looks like.
    rtourn - 답글
  8. TI-89 Titanium Power Button Replacement: 8 단계, 이미지 1/1
    • Peel back the rubber grommet sheet.
    • Make sure that the buttons remain attached the the rubber grommet as you remove it.
  9. TI-89 Titanium Power Button Replacement: 9 단계, 이미지 1/1
    • Remove and replace the On button.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dan Stahl
회원 가입일: 10/01/17
156 평판
안내서 1개 작성함
Michigan Tech, Team S5-G3, Galliah Fall 2017 Michigan Tech, Team S5-G3, Galliah Fall 2017 회원
MTU-GALLIAH-F17S5G3
3 회원들
안내서 1개 작성하였습니다
댓글 한 개
Thank you, fixed my sticky keys / juice spill damage.
Martin Olsson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 56
전체 시간: 3,389
