주요 콘텐츠로 건너뛰기
TILT Scooter Wheel Replacement
필요한 것
  1. TILT Scooter Wheel Replacement, Wheel: 1 단계, 이미지 1개 중 1개
    • Flip your scooter upside down where the handle bars and wheels touch the ground to prepare the extraction of the wheel.
  2. TILT Scooter Wheel Replacement: 2 단계, 이미지 1개 중 1개
    • With the Y-tool, loosen up the screw by turning counter-clockwise.
  3. TILT Scooter Wheel Replacement: 3 단계, 이미지 2개 중 1개 TILT Scooter Wheel Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the scooter to the opposite side, and insert and push the Y-tool through the same hole where the screw was removed to extract the parts.
  4. TILT Scooter Wheel Replacement: 4 단계, 이미지 2개 중 1개 TILT Scooter Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the new wheel and adjust the optional 10mm hex nut to support the wheel's.
    • The 10mm hex nut helps keep the wheel from wobbling, if there was no nut then proceed to the next step.
  5. TILT Scooter Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • Insert the axle from which ever side and the opposite side to help adjust the hex nuts as you insert the axle easily.
  6. TILT Scooter Wheel Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the bolt and turn clockwise to tighten up the bolt.
  7. TILT Scooter Wheel Replacement: 7 단계, 이미지 1개 중 1개
    • Flip your scooter upside up and move your scooter around to detect any lose movement.
    • If there is no wobble. Congratulations, you have successful replaced your wheel!
결론
To reassemble the wheel from the back of the scooter repeat step 1, follow the instructions similar to the front wheel.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
juaka_47
회원 가입일: 04/04/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 343
